Yeah i didn't think it add any power. It just out an has no use.an 90% of the time i just roll down the windows anyways. Just thinking it be a good way to free up some pounds.
well then is $50.00 worth shaving off ~10 lbs from your car? (Now this might be a different story if the ac clutch itself is bad, mine would lock up so I either had to replace it or remove it, but if your compressor is just out, you could probably leave it on the car with no worries)
its definatly more than 10lbs, i would say roughly 30-40 lbs all together, dont buy the pulley if your interested I can show you how to do it with just a smaller belt if your interested let me know.
ok the belt your going to need i believe is a Gates K060888. Here is a diagram of how its routed, you will need to loosen the tensioner of the block in order to slip the belt under the pulley.
I have some pics below to give you a better idea, and thats about it, cheap and easy. you will also need ac line disconnect tools which are cheap and you can get basically anywhere.
