getting dyno tuned tomorrow!
Old May 3, 2010 | 04:07 PM
kugzgt's Avatar
kugzgt
Default getting dyno tuned tomorrow!
finally finished all my ****! im scheduled for my dyno tune tomorrow morning! will post numbers and vids tomorrow. i know alot of you guys are curious about the mhs cams
Old May 3, 2010 | 04:14 PM
tbirdscwd's Avatar
tbirdscwd
I'll be interested in seeing how those cams measure up to their reputation. Did you degree them?
Should be decent power with cams and a bump in compression.
Old May 3, 2010 | 04:18 PM
kugzgt's Avatar
kugzgt
unfortunately i did not degree them. i dont have the tool for it and i dont know anyone who has one, but i checked for clearance about a million times before i put it all together
Old May 3, 2010 | 04:22 PM
02stang2113's Avatar
02stang2113
What do you plan on getting?... whats your hp goal???
tbirdscwd's Avatar
tbirdscwd
Not the end of the world. It should still make good power. Much more power than a NPI!!!
Old May 3, 2010 | 04:31 PM
mrtstang's Avatar
mrtstang
What clearance did you get? Did you know that MHS sells adjustable crank gears, and matched cam gears, so you don't have to degree? That's what i got as my cams came 5 and 7 degrees retarded from Bullet.
Old May 3, 2010 | 04:38 PM
tbirdscwd's Avatar
tbirdscwd
MHS's website says they don't sell the matched cam gears anymore???? What's up with that? And why does nick use bullet to grind his cams if they come that far off? Do other companies give similar results?
Old May 3, 2010 | 04:44 PM
kugzgt's Avatar
kugzgt
i dunno i asked nick about the cam gears and he said they dont have them
Old May 3, 2010 | 04:50 PM
mrtstang's Avatar
mrtstang
Really??? I just did mine a month ago. I'm not sure what's up here. According to Nick it's not just Bullet with the issues. Comp, and the other major grinders have these issues as well. Although, from what i gather mine were a little farther out of spec than most.
Old May 3, 2010 | 04:56 PM
dimebag's Avatar
dimebag
Recently it has been realized that the stock cam gears aren't as far off as we think...thry aren't perfect but they're just part of the problem. The real issue is that the cam manufacurers can deffinatly guarentee that all the lobes are in sync w one another...but thry can't promis that they are 100% in sync with the keyway...therefore adj cam gears are needed.
Sorry for the **** typing...im posting from my phone
