Methanol Injection...
Old Jun 21, 2010 | 12:44 AM
  #21
01MGGT's Avatar
01MGGT
Goto anderson ford motorsports website and look at the mr.freeze kit. I think it is 200 bucks top and all you need to install it is a drill bit (unless you have the powerpipe) and some zip ties. It installs in maybe 20 minutes as it works off vacuum.
Old Jun 21, 2010 | 01:06 AM
  #22
Harryman2002's Avatar
Harryman2002
Alright will do.
And you absolutely have to tune it on the dyno?
Old Jun 21, 2010 | 01:19 AM
  #23
MustangMan00's Avatar
MustangMan00
dang it 01MGGT post pics!!! your killing me, I'll probably get that kit eventually(brakes are in the mail now ) but id like to see exactly what this kit looks like and how it ties in/mounts
and to the OP, I agree with 01MGGT without any cooling your car will be a DOG daily driving, unless the ambient air is pretty cool, then you make lots of power! haha
Old Jun 21, 2010 | 01:36 AM
  #24
Harryman2002
Haha well that sucks then because lately its been in the high 90's.
I guess an intercooler/meth will without a doubt my next mod, as soon as possible.
Old Jun 21, 2010 | 09:19 AM
  #25
smythge's Avatar
smythge
I have the AEM kit and it took me about 3 hours to install, with the wiring, drilling, plumbing etc. It has a progressive spray based on the amount of boost, it also has a fail safe warning system with the ability to activate a bypass valve or wastegate should the system fail. It also has an LED indicator, which shows you when it's spraying, or if there is a problem with the system (wiring short, low fluid, overheated pump etc)
I have the IAT sensor mounted after the injection and if the intake temp gets too hot the PCM will pull timing.
I wouldn't run a methanol/water injection kit without some sort of fail safe operation, how does the Mr. Freeze kit work?
Old Jun 21, 2010 | 10:06 AM
  #26
2000AZ5.0GT's Avatar
2000AZ5.0GT
Methanol Injection uses evaporation and the enthalpy gained from it to cool the intake charge.
When a liquid evaporates, maybe as you've noticed when you're getting out of a pool, you actually lose energy (kenetic energy), resulting in cooling. This has alot to do with the nature of water and such, so it's much more than you need to worry about to know how it works
Anyway, when the methanol is injected into the intake charge, as long as the mist isn't too dense, the water will evaporate, especially given a 100+ degree intake charge before the injection. This will drop the temperature drastically, depending on how much you're spraying.
The Methanol acts as an octane "booster" because methanol alone burns at 120 octane I believe. Being that it's essentially being mixed with your premium gas, it results in you running essentially 104-105 octane.
99, the IAT should always be mounted close to the throttle body in an FI situation, otherwise you're asking for problems. In any case, the high octane shouldn't be relied upon, I agree with you, but even lowering the intake temps results in less chance of detonation, meaning that if the nozzle were to get plugged, higher temps alone could cause pinging/detonation.
if the IAT is kept near the throttle body, you can minimize this effect, and if the temperature noticeably gets higher during boost, timing can be pulled, which it should be anyway.
Meth is very reliable. I was running in SCCA for quite some time using Meth alone.
I do however always recommend going FMIC. It's much MORE reliable, and it's essentially set it and forget it. No tanks to keep filling, no nozzles to clean, nothing. Not to mention, no matter what, it's going to be unbelievably consistent.
Old Jun 21, 2010 | 10:21 AM
  #27
PurpleIcedGT's Avatar
PurpleIcedGT
2000asianGT.....this f'n guy is knowledgable. Good writeup!
Old Jun 21, 2010 | 12:53 PM
  #28
Harryman2002
That was a great description.
Thank you for that.
Old Jun 21, 2010 | 08:32 PM
  #29
01MGGT's Avatar
01MGGT
ok ok lol. Here are the pics. It has one vacume line that t's into the bypass valve vacuum and the other line goes in just before the blower. If you have a powerpipe it already has a hook up for it according to the instructions. Impeller erosion is not an issue according to numerous people and sources.
As you can see it is very cramped in our engine bays so I zip tied it to the support rod for the coolant tank. I had no issues at 100+ mph at the track or when going wot around town. System has performed flawless and I even bought it used. Data logs proved there were instant results!
Old Jun 21, 2010 | 10:39 PM
  #30
MustangMan00
thank you! haha and there isn't already a spot on my power pipe, but its as easy as drilling a hole hah
I'll prob. do this after a few more paychecks...thanks!
