magnapacks to magnaflows swap possible?
I got a magnaflow (magna-packs) style cat-back, If i swapped mufflers with the regular magnaflows from someone elses magnaflow cat-back would it fit?
wasnt sure If it would fit because I did notice how the magnapacks do have a curve or bend on the end of one of the outlets.
^ are you from Johnston??
This is a small world if you are...I'm the one prob coming to swap mufflers with you. I made the SAME thread in the other section.
https://mustangforums.com/forum/4-6l...hangeable.html
yea, just double checking.. because I called up magnaflow directly and they said It would not fit... And if you look at the pictures its not the same cat-back, the offset is way off. Really dont think there gona fit.. You can call up or check out how much the two cat-backs are different
^ Yea I just called and asked. Tech said the only difference is the pipes from the midpipe to the mufflers..and then the mufflers themselves. So the pipes over the axle are identical.
Which isn't bad, I would unbolt the front section from the midpipe anyways to get the mufflers out. So I can give you the front section of pipe as well as the mufflers. And you give me the front section of yours and the mufflers.
PM me, so we don't start messages back and forth and waste room on the boards.
haha... and im the one who commented on the other thread YES it'd work. I just came across this thread and though, "what the heck!??.... Wasn't there just this same thread made yesterday?" Wow.... what are the chances that this ^^^^^^^ happened the way it did? ahahahhaha
Matt's 95 Stang
10-05-2015 07:16 AM
