Hitech stage 2 cam hp numbers
#21
What "kind" of numbers would you expect from his combo?
I have nearly the same combo as him with the following exceptions: I have the Bullitt intake and TB, I have stock flywheel and drive shaft(which are parasitic to accelleration numbers), I have 4.10s(which don't matter on a dyno). My car made 301rwhp & 309tq. On DRs it runs 12.80 @ 111mph with NO CLUTCH ABUSING HIGH RPM LAUNCHES so 1.85 second 60'. If I were willing to abuse it more I could probably run in the 12.6s or 12.5s.
#23
This ^^^
#24
#25
It will be interesting to see what trap speeds his configuration runs. That should shed some light on how much power the car is making. It may be one of the stronger cars with this configuration. Have to wait to see...
#26
I run at Island Dragway in Great Meadows NJ. I almost fell over after the 1st dyno pull. It was a consistent 313-315 on 3 pulls. I got it dyno'd at Big Daddy Performance and their tuner was pretty knowledgeable.
#27
Good luck when you go to the track! Let us know how it goes.
#29
I had the cams installed by a local tuner. Cams and install was only $1100, and worth EVERY PENNY!!! I also added the long tubes at the same time and gained 47RWHP all together. You won't regret the cost of the cams.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
