HELP!..Driver side window stuck down!
Old Jul 25, 2010 | 03:24 PM
AustinBoston17's Avatar
AustinBoston17
Default HELP!..Driver side window stuck down!
Went for a drive to pick up the gf and get some gas. Rolled the window down just like everyday but when I pulled in the driveway it wont go up
The passenger side goes up and down fine. I cant hear the motor running when I press the button. But I do hear a click noise. I removed the buttons from the door and tried moving the one from the passenger side to the drives side to see if it was simply a faulty switch. The passenger side one switched over didnt work either. Now im stumped. Please help, I need my window up :/
Old Jul 25, 2010 | 03:41 PM
AustinBoston17
So I called a local guy that does this and found out that I can punch/kick next to the speaker while holding the window up button.
I guess it's my motor.
Anyone know how much they run?
Old Jul 25, 2010 | 03:46 PM
Rockwell28's Avatar
Rockwell28
check carparts wholesale they start at like $45 it may not be th motor mine does the same like 2 times throughout th month then just starts wokin within th same day
Old Jul 25, 2010 | 04:28 PM
945LSTANG's Avatar
945LSTANG
you sure its not the "one touch" module or whatever the F ford calls it? if those go bad your window motor will act like its not plugged in. i would test it with a multimeter before you start throwing cash at a problem that might or might not exist.
Old Jul 26, 2010 | 04:04 AM
mvr's Avatar
mvr
i have had this problem two or three times. like stated i had success with the hit/punch method while holding the window up/down button. did you try that and it didnt work? the instances are too far apart in time for me to start troubleshooting it on my car, so i havnt looked deeper into it. i figure its just another "feature" included in my deluxe package gt lol.
Old Jul 26, 2010 | 12:17 PM
Rockwell28's Avatar
Rockwell28
shoulda kept my mouth shut on the subject bc mine just started it again today its stuck in the up position again and i tried kickin the speaker while holding the down button and it still wouldnt go down
Old Jul 26, 2010 | 01:54 PM
code3GT's Avatar
code3GT
Mustang Nazi
Uep, just bang next to the speaker on the door panel. I had it happen on the Bucket twice. I never had to replace the motor. Hope you are as lucky.
Old Jul 26, 2010 | 02:23 PM
AustinBoston17
The hit/punch method worked for me.
I hope this doesnt keep happening. I have better ways to spend the money I barely have lol
DreadPirateRoberts
Sep 26, 2015 02:11 PM
gagemcc
Sep 22, 2015 09:43 AM
wishinsky
Sep 21, 2015 09:48 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2k232
Sep 16, 2015 10:28 AM
