Strange noise from wheel
LMFAO....@ teej+natedog...
EE ima start calling you Kumar...
OK Kumar, did you happen to look to see of the tires are cupped? Have you checked to see if the hub assembly has any play it? Tie rod ends? As you say, swap the tires and see if the sound is still from that side...
Alright, so I haven't had time to swap the front and back.
I left out an important detail about this issue. If I go around even the slightest RIGHT hand bend on the highway, the noise completely stops. Once the wheel straightens back out though, the noise comes right back to what it was. If I go around a left hand bend, the noise stays the same and does not increase in loudness or anything.
Alright, well, an update. Switched the tires, noise is still there. My friend who is a BMW mechanic told me that it is likely a bearing just howling. When I turn the wheel, there is less stress on the area of the bearing that is bad. Thoughts?
