eaton or vortech
eaton or vortech
hey guys, ive always wanted a vortech v-1 or v-2 but i have just found a good deal on a eaton modular S/C but i dont kno much of anything about them or how to install them can you guys help me with the pros and cons? and a estimate on rwhp id hav wit stock block
The Eaton blowers on the 2V, like what's on the Saleen SC281's will put out no where near what a centrifucal blower does as far as power goes. The whine of the roots style blowers sound cool. But if that's the type blower (Eaton) you can get a good deal on, "I" would pass and save up for what you really want. Just my .02
the eaton has a lot of heat issues too iirc. You get a lot more low rpm torque/horsepower vs a vortech but the vortech makes power in the upper rpms. So ask yourself, where will I be using my power band the most?
Like mentioned before the 2v eaton swap is expensive too, the ports on the 2v are not the same as the 4v and the manifolds for 4v can't be used. You need a special manifold for your case. Also remember that the GT hood will not clear a eaton S/C with the special manifold, so a new hood will need to be on your list as well...
Prob better off with a used vortech head unit and buying the extra pieces you need piece by piece.
If you're a centri car you will use your power the most in the high end....because its not there in the low end. If you have roots/TS you will be using your powerband the most all over, because you have the power all over........It's no less useful @ 3k than 6k.
I vote Vortech. OP as has been mentioned in order to put the Cobra Eaton M90 blower on your car you will have to have a special intake that costs $2,000 this build is not worth it unless you have cash falling out of your pocket. An intercooled or aftercooled vortech setup will net you more power and torque. Once you start running the eaton hard repeatedly it has a notorious heat soak issue, hence the name nickname "heaton."
Eating can be done for about 3k if u find a lot of good used parts but vortech is cheaper and more reliable. I've seen hella nice # on an eaton 2v tho. Best is a factor but running less than 10psion on a stock 2v with a good heat exchanger should b fine. #s I saw were roughly 390/440 on about 9 OSI
