Wheel questions and concerns
The ONLY place I would consider getting wheels widened/repaird is Weldcraft Wheels.
The cost per wheel (reguardless of how much wider/narrower) was $225 per wheel about 2 years back. I figure it has gone up by now, but would need to call to confirm. You can actually see your local kitty cat's ride in the customers gallery
By the time you pay shipping to/from, expect another $200 or so, depending on where you live and local shipping rates. Remember, that the wheels will ONLY get wider via back-space and why spacers are gonna be required on a Mustang wheel. I suppose if one spent the time to find a wheel that would fit the Mustang, but has a much more positive off-set, you "may" be able to avoid a spacer. I know teej already figures to use them, so just a bit more info for y'all.
My wheels began as Saleen 9" & 10.5" with standard off-sets and fit OEM rides just fine. The fronts were made into a 10" wheel due to clearance afforded by SLA and rears were widened 1/2" and moved outward 1/2" via spacers and longer studs. I have NO room in ANY direction in which to go wider/taller tire, so why I say an 11" wheel is max for proper fit.
Jazzer
Btw, it's 225/wheel to get widened, and second of all you always make jabs about me not having power mods or wanting to not be the same as every other mustang out there. I'm all for a joke, believe me. But what you're doing is not joking, as all you ever do in my threads is make jabs about me wanting to be different and for having all the suspension work I have done and no power. It's kind of obnoxious and it needs to stop.
Jazzer
Jazzer
Proper fitment for an 18" wheel with 315's is 11" width. With a 10 or even a 10.5" wide wheel you effectively lose some of the tread patch to act as sidewall. When youre running a 17x10.5 wheel, its alright because there is more sidwall to "bulge"(not that it does, just more of it there to act as sidewall) and allow the full tread patch to meet the road. Does that make sense?
People are out there hooking and doing fine with 10" wide wheels with the right tires.
And I don't jab you in every tread you make. Quit being so sensitive, you're reminding me of my 13 year old sister.
Jazzer.... likes it tight!
Oh Jazzer. Lol but with the regards to width, when my build is all said and done, I'm going to need all the tire I can get. I don't want to reveal my build just yet as I'm trying not to build hype and then it doesn't happen. Right now it's in the planning phases and will be put into motion around tax time.
No matter HOW you slice it, gettting more tire without more wheel to support it.. is a complete waste!
Go ahead and squeaze a 365/15/17" on a 10" wheel and will be WORSE off than a 315/35/17" on a 10.5" wheel.
Jazzer
Jazzer
