Cams
Old Sep 21, 2010 | 08:53 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
Originally Posted by nickmckinney
Its simple, they don't know. Once you actually measure these things you usually stop posting a bunch of BS.
BTW - stock springs are fine with the Comp270 even though Comp says otherwise and wants you to run their springs with pretty much the same specs as the stock springs............
Maybe they don't know specifically because they didn't do the install, but they actually have the cam in question and it worked without issue. Thus, the "assumption' is that they do work if not installed "INCORRECTLY." That is nearly the same thing as saying if "INSTALLED CORRECTLY."
Just a thought...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
