Nitrous or suspension?
Old Sep 22, 2010 | 12:27 PM
  #21
teej281's Avatar
teej281
4.6L Section Moderator
And my friend launched at 3500rpm and completely screwed his axles and diff up...on a bolt on car with 4.10's and a 100 shot. So, as dime will tell you, with dr's and 28 splines, you're running on borrowed time.
Old Sep 22, 2010 | 12:28 PM
  #22
natedog's Avatar
natedog
Just do both
Old Sep 22, 2010 | 01:38 PM
  #23
jimkaray's Avatar
jimkaray
Originally Posted by KillJoy
you can 5k clutch drop an 8.8 on drag radials without going to a 31 spline set-up. for a car making ~350rwhp 28 spline will be fine. look at dimebag, he launches at 5500 drops on a radial and sprays it.
Well, you could both be right. As KillJoy stated HP & torque are two different things. HP isn't breaking anything, its torque that measures the leverage that is going to break a weak component. Also, HP peaks in the upper rpm range where as torque peaks in the low rpm range. Nitrous (which adds more torque than HP) adds its max torque down low and drops off in the upper range. So my logic says a high rpm launch with spray should theoretically be easier on the rear given that both cars have similar set ups and power curves. The low rpm launch is the more abusive of the two.
Old Sep 22, 2010 | 04:22 PM
  #24
mustangmancp's Avatar
mustangmancp
Id do gears/axles....then suspension. Then you can do as you please (until your clutch goes )...but thats another thread haha.
Old Sep 22, 2010 | 04:38 PM
  #25
teej281's Avatar
teej281
Mustangmancp's got the right idea!
Old Sep 22, 2010 | 06:56 PM
  #26
stltwn76's Avatar
stltwn76
well i def have pretty much heard what i had already known suspension is key. i will def be doin those upgrades as time goes on. sfc, tires, 10.5 in wheels in the back and shocks have been what i been thinkin about lately. appreciate everyone input
Old Sep 23, 2010 | 03:12 PM
  #27
TRUEBLUE3934's Avatar
TRUEBLUE3934
I don't think this is sound advice. If you plan to launch it hard at the track, you will put 31 splines in it eventually. You should do it BEFORE you break it at the track. I have seen factory 28 spline axles broken by cars with far less than 350rwhp. If you shock these axles, you can break them. Everyone is entitled to what they wish, but to advise someone else not to upgrade to 31 splines before abusing it at the track, is not helpful to them.
My 2 cents...
Old Sep 23, 2010 | 04:28 PM
  #28
dimebag's Avatar
dimebag
31spline **** isnt needed.....i have plenty of proof to back that up...
Aaand for the record my 100 shot is jetted to be 100hp at the tire lol
Old Sep 23, 2010 | 04:38 PM
  #29
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
People.... Horse power has NOTHING to do with breaking things.... it is GRIP! If you get enough "hook", you WILL break the weakest link in your driveline. All DR's are not created equal, so this cannot be the sole deciding factor in when to upgrade axles and such.
In general, if one is going to be hitting the track and always looking for that illusive 1/10th..... just upgrade the **** out of EVERYTHING on the driveline to be safe.
To focus on upgrades only as HP/T climbs, is a mistake.
Jazzer.... givin' it to his pepes, hardcore like
Old Sep 23, 2010 | 04:46 PM
  #30
dimebag's Avatar
dimebag
Jazzer.... if i WILL break something then explain this
5500rpm dumps on a set of 275/50/15 mt dragradials...just to give u an idea of how well it hooks it hangs the fronts a goood 6 to 8 inches when it launches.....
And im on stock rear **** with 4.10s
