REAR END LEAKING!
Old 09-21-2010, 12:40 PM
TheNameless
TheNameless's Avatar
Default REAR END LEAKING!
Hey fellas, i made the common error when i re-did my brake pads i just used a jack and jacked the car up in the rear end with the jack under the gear diff cover ( now i know to use a piece of wood to evenly distribute the pressure) but now its slowly leakin....son of a b*tch! But my question is can I just replace the differential cover with something like this? http://www.americanmuscle.com/gms-79...le-system.html
It comes with gasket for it and everything else, or am I going to have to take it to a mechanic and get charged like 500 bucks? If i can do this myself do i need to jack the car up or anything? Please guys help I feel like im on a bad streak with my car ( bad idle,fixed due to holes in tubing by RAI, needed new pads ( took 5 hours cuz I thought that a C-clamp would push the piston on the caliper back in turns out i had the screw it back in with vice grips), now my diff cover is leakin.)
Thanks, Nick
TheNameless is offline
Old 09-21-2010, 12:47 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
From the sounds of it a new rear diff cover and gasket will fix your problem. Don't take it to a shop. Read the write up on americanmuscle.com on how to install it. New fluid will be needed also.
WannaBeGearHead is offline
Old 09-21-2010, 01:01 PM
TheNameless
sweet! thanks GearHead, I know for sure if i wanted new gears then i would have to go to a mechanic, but for just replacing the diff cover its pretty much just unscrewing a couple bolts and rescrewing them thanks!
Old 09-21-2010, 01:52 PM
Z28KLR
Z28KLR's Avatar
Most people prefer RTV sealant vs. a rubber gasket, less likely to leak (factory uses it as well). Just put a nice bead of it on the housing before you install the cover; might need to wait an hour or two for it to set up before you add fluid. And something to think about if you're replacing the cover is to get one that has fill and drain plugs to make the job of changing fluid easier for next time.
Z28KLR is offline
Old 09-21-2010, 02:09 PM
teej281
4.6L Section Moderator
teej281's Avatar
Diff cover takes nothing special to do. lol it will make it easier to have the car up in the air a bit, but all you gotta do is take the old cover off, clean off the surfaces that you'll be putting sealant on with some mineral spirits or something like that to make sure they are clean and free from contaminants, and then put the RTV on, bolt the cover on and torque the bolts down if necessary, and then after a few minutes(or however long you gotta wait for it to set) add the diff fluid with friction modifier if it is needed. Now make sure that you have the right amount of diff fluid as i know some diff covers require more fluid as they increase the amount of room to allow more fluid for better cooling, so just make sure you put enough fluid in and you'll be good to go.
teej281 is offline
Old 09-21-2010, 08:52 PM
steve0914
steve0914's Avatar
i replaced mine, its easy but that smell never goes away
steve0914 is offline
Old 09-21-2010, 09:04 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
For future reference, from the factory shop manual:
"CAUTION: Under no circumstances should the vehicle ever be lifted by the suspension arm brackets, rear stabilizer or differential housing or convertible cross brace. Severe damage to the vehicle could result." [emphasis added]
cliffyk is offline
Old 09-22-2010, 12:00 PM
TheNameless
okkkkk where do it put the jack next time for future references, if i cant use the differential housing?
Old 09-22-2010, 12:34 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Jacking points...
cliffyk is offline
Old 09-22-2010, 12:38 PM
PurpleIcedGT
PurpleIcedGT's Avatar
Its pretty funny that Cliff just taught you where to jack from....LMAO!!
PurpleIcedGT is offline
Quick Reply: REAR END LEAKING!
