Got Code P1181
Ok so I installed my struts, shocks and lower ball joints and took the car for a test drive and Check Engine Light came on. So went and got it scanned and got P1181. Any ideas what it could be? I did notice it was idling rough at a red light? Says on bank 1 it could be a plug, lean condition or something like that.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
My tank is low on fuel and I did hammer it. I wonder if the fuel pump sucked air causing this code???
It runs good. Maybe my fuel gauge is off??
Damaged HO2S
Damaged PCM
Fuel System:
Induction System:
Vacuum Leaks
PCV system
EGR System:
Leaking gasket
Stuck EGR valve
Base Engine:
Oil overfill
Cam timing
lincolnshibuya
Dec 8, 2015 04:37 PM
