Super pissed
Old Oct 17, 2010 | 05:05 PM
hpwrestler220's Avatar
hpwrestler220
Mine does it as well...
Old Oct 17, 2010 | 05:28 PM
Harryman2002's Avatar
Harryman2002
Originally Posted by MU71L4710N
its actually a pretty common problem with this transmission, mine does it too. just don't try to slam it into third and you'll be fine, almost like your shifting around town but a little quicker.
Trust me, ive tried that too. It literally doesnt go in no matter how gently or forcefully I try above like 4500RPM's or so.
Old Oct 17, 2010 | 05:52 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by Harryman2002
Not sure about the transmission fluid, I was gonna get that changed out pretty soon.
And no, I dont have an aftermarket quadrant.
Anyone know the average price of a used t3650?
Then drain it and refill with 3.2qts of Mobil 1 ATF.
If it's never been changed, or was changed at a dealership that never reads TSBs unless there's a problem, then it likely has 3.8qts. If it was changed at a Jiffy-Lube type place then they probably filled it to the fill hole which means it is grossly overfilled (4.1+qts).
It may be too late and the damage has been done, but you might have caught it in time.
This TSB explains the problem, it's only "common" in 3650's that were never properly serviced...
Old Oct 17, 2010 | 06:05 PM
Harryman2002
Cool, Ill try that. Hopefully thats all it is cause I don't really want to have to drop more cash on a transmission.
Old Oct 17, 2010 | 06:11 PM
boduke0220's Avatar
boduke0220
i think its pretty common, both my friends machs did it, and mine started doing it a while after mesit bought it. GT hasnt yet though, my friend did the t56 swap on his car and im pretty sure he used a cobra driveshaft but i will ask
Old Oct 17, 2010 | 06:33 PM
PurpleIcedGT's Avatar
PurpleIcedGT
Damn, good luck getting it figured out bro.
Old Oct 17, 2010 | 08:48 PM
teej281's Avatar
teej281
4.6L Section Moderator
http://www.promotionpowertrain.com/1971777.html
scroll to the bottom. T3650 built for 750+hp. Buy that and it will be a direct swap.
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
M3hunter
Sep 5, 2015 03:42 PM
aleit2013
Sep 4, 2015 11:58 AM
Luke9222
Sep 4, 2015 06:46 AM
S197 Shelby Section
Sep 3, 2015 03:04 PM
