Griggs Panhard bar or skip it?
There are couple common ways to rid oneself of the UCA's (< horrible little creatures that they are ) and a WL or PHB with a TA is wonderful way. They are now out of the equasion and your car is FAR better at hitting the twisties
SLA = Short Long Arm:
This is a set of twin front control arms that apply increasing negative camber as the front suspension is being compressed. This keeps the outside tire flat to the road surface throughout the travel of the wheel.
Jazzer
Jazzer
^ Flat or perpendicular to the road surface when cornering. Negative camber will keep them tilted upon level/straight driving.
The upper control arm, talkin' up front here, is shorter than the lower one and why it's called SLA. Take a look at the following vid to see how the front tire contact patch remains consistant thoughout the path of compression:
SLA vs. MacPherson strut
Pay particular attention to the 2:15 mark and beyond to see how effective it is under body roll. This is an Agent47 set-up and not Griggs, but operate in the same way.
Jazzer
Jazzer
I see I have mine right now set up for negative camber, only because i dont have cc plates. The only downside is the inside of the tires get worn out quicker than the rest. I definitely want to get into the suspension aspect of this car.
thanks for all the responses everyone i always wanted one and this is a killer deal. trying to get in contact with the guy selling it is the only delay now but it has been up for sale for a long time so hopefully its still there!
Jazzer
Oh i noticed a drastic difference in cornering after i replaced everything with tokico blues and tokico red lowering springs and with the neg camber. I am hooked and want to push it further but the funds are not there .
See if you can swap someone for an IRS. It will wake the car up quite a bit.
