Turbo Time!
Old Oct 26, 2010 | 05:08 PM
  #21
Dteal23's Avatar
Dteal23
Originally Posted by mustangmancp
Well i mean im wanting numbers...but don't wanna be a slouch on the street...
Apparently this isn't possible lol.
lol then y not the 2.8? u can get 550-6 out of that. There is a dude on svtperfomance that has 600 with his 2v Kb set up. I forget his name bet he is close to me in so-cal. do what you want its your car and your money lol
Old Oct 26, 2010 | 05:15 PM
  #22
mustangmancp's Avatar
mustangmancp
I mean realisticly i want the KB for the INSANE torque...i just was just kinda seen what was needed for the same numbers and relatively good torque.
Old Oct 26, 2010 | 05:18 PM
  #23
H0SS302's Avatar
H0SS302
Ull get just as good if not BETTER torque from a properly sized turbo...
Old Oct 26, 2010 | 05:29 PM
  #24
teej281's Avatar
teej281
4.6L Section Moderator
You can get a killer setup with a turbo, you just have to setup the system correctly. You have to take into consideration the turbo size, the equipment of the turbo you chose, piping diameter, heads being used, cams being used, intake being used, compression, fuel being used, etc.
Start out with your goal, then you start asking key people very important questions...especially since youre this far along with a built motor, heads, and an intake all setup for high rpm performance. You'll have to start talking with people like Nick and Jim Cushman to really nail your cam choice so you dont give up too much spool time. Also, you'll have to start researching what turbo(s) will be optimal for your setup. I was talking with hoss the other night about turbos for about an hour and a half. He knows quite a bit, so i'd ask him some questions and pick his brain. But you have to pick out a turbo that is going to fit your needs and still spool rather quickly if you want to be a threat on the streets.
Like I've said before, your car is one setup. Everything needs to be working together to make it work to its potential. Your car unfortunately has a lot of high rpm potential, which is why its going to be crucial to pick your cams and turbo wisely to help it have quick spool and not a horridly high peak.
Also, word on other turbo forums, like for buick gnx's and imports, is that billet wheel turbos spool quicker and make better power than cast wheel turbos of larger sizes. Something to throw out there.
Old Oct 26, 2010 | 07:35 PM
  #25
kugzgt's Avatar
kugzgt
http://www.youtube.com/watch?v=3BklC...eature=related
Old Oct 26, 2010 | 08:01 PM
  #26
teej281's Avatar
teej281
^Thats gonna be cp with a turbo...lol good vid kugz
Old Oct 27, 2010 | 07:21 PM
  #27
ddmsgtr1's Avatar
ddmsgtr1
Check out turbochargedinnovation.com. One of Nick's customer's is running this kit with a Master Power turbo from an on3 kit and I believe is at or above 700hp and ran in the 10.0's or 10.1's recently. And the kit comes with a Precision billet 67mm, which is supposed to be much better than the turbo he's running. I'd consider dropping to a 3.55 or even a 3.27 gear, turbo's a load sensitive, so this should help your spool. Also, as someone else said, an auto will spool faster, but if your stuck on owning a manual like I am, I think a transmission with a longer first gear would be something to look at while you're beefing things up.
bjdutch2005
Mar 24, 2017 03:38 AM
Luke9222
Oct 22, 2015 11:55 PM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
