Time to start finding vortech parts!!!
I have an 01 Roush Stage 2 w/78mm BBK throttle intake, 44lb accel injectors, accel cop's, BBK long tubes, O/R X-pipe, Spine tech side exhaust, BHJ balancer, Spec aluminum flywheel, spec stage 2 clutch, VMP slot style maf, Anderson power pipe and a P1SC pushing 11/12 pounds. My car is putting down 402H/414T w/17 degrees of timing on 91 pump gas. It also has a 3 core sheet metal intake. Whatever you do, make sure it is inner/after or chemically cooled. If not, you'll have to retard timing and lose power.
dunno if somebody said this yet:
s-trim stands for street trim
t-trim stands for track trim
t-trims push more air, and will get you well over your desired power level. I am over 400 rwhp on 7.5 lbs of boost (on a bad day) with my t-trim (but also I have cams)
so a t trim is a bigger blower????by diameter?? and pushes more air. ok i might consider that because of the fact you could tune it down to less psi for amount of power of high psi s trim. or would i have to have a blower cam for the t trim and not the s??? really appreciate the help guys
T-Trims are a better blower over an S-Trim because of 2 reasons. 1) They can be spun faster and thus create more CFM or boost than an S Trim. and 2) When spun faster they become more efficient than an S Trim and produce less heat so you are able to run more timing.
