Next Mod?
No one has mentioned Subframe connectors, they are often overlooked. They are critical for any suspension mods working well. Even on my DD mustang they were awesome.
Like mentioned above pullies are pretty good, they free up some torque and you'll get better mpg with them.
Perhaps an AEM wideband sensor so you can fine tune your sniper tune? I personally saw +11rwtq when I fine tuned my canned sniper tune with a wideband. They run pretty rich... Plus you can adjust your cruising ratio to a hair lean to increase mpg too if you want to save some $$$
How much more do you think I can get out of it if I already have the 93 octane tune done if I get the wideband? If it's only a few hp it's probably not worth it, but 11 is probably worth it.
My car is just a DD, it won't ever see an auto X; what would you recommend in this case? I don't really want to lose ground clearance especially if I ever decide to go with lowering springs; do any of them hang lower than others?
I was just'a showin' off to the youngins here
MM is gonna be great for all but the most extreme hard-core and still good for most of those folks too!
I will ask what I always do in the cases such as yours...
What is the ULTIMATE goal for your ride?
Jazzer
Jazzer
"jazzer rockin out"
I'd just get a set of MM full length sub frame connectors (powder coated)... they're like ~$10 more than any other "name brand" ones and you can't go wrong with them. They're my next mod....
yea, subframes are really good. I too did a one jack stand trick, it doesn't look as good because there is some lean in the front sway bar since its stock but the deflection is almost nil. Of course I have the upper along with my MM lowers.
If you go the wideband route then you can tune your fuel alot better. I tuned my fuel in from ~12.1:1 to 13:1 and adjusted the timing to 24-30 degrees at WOT (canned 93 tune to 93 adjusted). my torque went from 275 to 292 which is 17 but I also added steeda pullies too so I figured ~5 for them.
Either way is worth it even as a DD
Actually here's a question for you (or anyone else) since you brought up connectors. Say I was going to turn this into a drag car at some point in the future (I actually do plan on this after the engine and such wears out), should I go for a different set of SFC, or would the MM ones do ok? Realistically, I say 10 second, but I might be more in the 11's when all is said and done. So basically I'm asking if those things would do well on an 11 second drag car as well as a DD.
What is the timing set at with the canned tune that comes with the sniper? I plan on upping my timing some from that and I'm sure that will gain some for me. Did you try advancing timing before you got the wideband and such? Or did you only advance timing after you had the wideband?
Say I adjust the canned tune timing to right before knock and such, and then decide to go with a wideband. How much more do you think I could get by having the wideband to go off of?
Wow, so you're saying from the tune that comes with sniper, to the tune you have now you gained that much? You're talking wheel as well correct?
Look on the forums for the sniper software (delta?) they sometimes post graphs of there tunes that work the best and you can use them as a template to start with your tune. I used someones pi swapped data and thats the timing they dynoed at the highest so I try to match there timing and used a 13:1 ratio for fuel. Even with bone stock rear suspension and sumi tires I was able to trap 104.76 mph with a pi swap and a few bolt ons.
I can post up a graph of one of my graphs for a year ago if you are interested.
