New Suspension
The bullitt suspension helps with handling because of the increased spring rate, but it uses linear springs, which also might add a little bit more to the harsh ride. But it also does not lower the car much. It lowers it 3/4" front and rear, which will be barely noticeable.
I had the bullitt kit on my car and it was pretty decent... I hated the rear springs however. Very soft and a lot of wiggle in my car when taking corners aggressively... The dampers are great though for the budget...
Only get the bullitt kit if you want great ride quality with slightly better handling... It's hard to tell you what to get and what not to get since idk you personally or what exactly your goals are, but i ended up cutting the front springs on the bullitt setup and switching out the rear springs for cut mach springs and i am completely satisfied with the bullitt dampers still.. So there is room to play with that kit IMO, but i would avoid it altogether and piece together something else.
Just my $.02
Just my $.02
