I need POWER
Old Mar 14, 2011 | 09:14 PM
  #71
Moonshine's Avatar
Moonshine
Those are called positive displacement blowers. There is no lag. Instant powaaaaaa.
Old Mar 14, 2011 | 09:19 PM
  #72
HamMach1's Avatar
HamMach1
So do they produce the same amount of boost instantly and throughout the RPM? So like... 9 PSI from 700-6800? Sorry... just trying to learn here I'd like to know about what I'm buying before I buy it.
  #73
turbo232's Avatar
turbo232
Originally Posted by HamMach1
I see! Now what about SC's like Whipple and KB? Where do the usually see their peak boost?
any time the throttle is open. they give 100% boost at idle-whenever
Old Mar 14, 2011 | 09:23 PM
  #74
mrtstang's Avatar
mrtstang
Originally Posted by turbo232
compared to an NA engine they dont. compared to a positive displacement blower everything lags and turbos only lag if they are setup wrong. the reason is design. centrifugals and turbos makes more boost the faster they spin. because a centrifugal is restricted by the engine directly on how fast it spins it will lag compared to a turbo. plus they operate in vacuum at low RPMs (under 2500 from my experiance)
Okay thanks. That's kind of what i though. I didn't know about the vacuum at low rpm's though. I think the term "lag" might get misinterpreted or misused sometimes.
Old Mar 14, 2011 | 09:25 PM
  #75
HamMach1's Avatar
HamMach1
Ok gotcha. Damn... I want a twin screw
Old Mar 14, 2011 | 09:29 PM
  #76
Moonshine's Avatar
Moonshine
Here are a few examples of dyno sheets.
Positive displacement.
Centri
Turbo
Old Mar 14, 2011 | 09:30 PM
  #77
turbo232's Avatar
turbo232
they are expensive and alot harder to cool. like someone said about the ported cobra blower earlier....easy to find.
Old Mar 14, 2011 | 09:34 PM
  #78
turbo232's Avatar
turbo232
turbo dyno sheets are so sexy.
Old Mar 14, 2011 | 09:42 PM
  #79
mrtstang's Avatar
mrtstang
The turbo dyno graph looks a lot like my nitrous graph in how it ramps almost straight up when it spools.
What's interesting between the other two is where the torque is made. At first glance the twin screw appears more impressive (and it is of course at lower rpm) but then the centrifugal carries the torque curve better in the higher rpm's. Of course it's not a fair comparison due to one having much higher overall power. I'd love to see a comparison between the two when they both have equal peak numbers.
Old Mar 14, 2011 | 09:59 PM
  #80
turbo232's Avatar
turbo232
turbo beats them all though. you make more power at the same bootst. a friend of mine in the amry has an 02 v6 with a procharger and at 12 PSI he had 308 tq and 270 rwhp and my v6 had basicaly the same numbers at half the boost. he also had a small cam, longtubes, o/r x and magnapack cat back
