Treadwear problems
Old Mar 28, 2011 | 07:06 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
What is this "snow" shìt? Sounds like it sucks...
Old Mar 28, 2011 | 07:12 PM
DreamerGT's Avatar
DreamerGT
lol yeah really
Old Mar 28, 2011 | 07:13 PM
99 GT vert's Avatar
99 GT vert
"winter tires" are very soft and designed for temperatures 45 degrees and below
if you have issues with the center of the tire wearing out faster i would run less air in them plain and simple i run 20 psi in my tires on the street and they are a 315/35/17 nt05r
Old Mar 29, 2011 | 12:40 PM
69MustangCoupe393cid's Avatar
Originally Posted by BraMas
Are you talking only your winter tires wearing out in the middle or do your Summer tires also wear out?
Winter tires are not designed to be driven on hard roads all the time. they are meant to be driven on icy/snowy roads. If your roads are always cleared of Ice/Snow in the winter they will wear out pretty quick
Summers wearing in the center as well. Also yeah I know about the dry road thing, but I'm more concerened about the center treadwear.
Originally Posted by teej281
Your blizzaks are a very soft compound according to my dad. You dont want to run them when the weather gets warm because they will wear out quicker than usual.
Yeah thats why I went with nokian wr-g2's this time around which are kind of an all season snow, but they're still burning up fast. Now I know the first few 32nds of tread is softer, but again my main concern is how bad the centers of the tires are wearing.
Originally Posted by WhiteFoxGT
Not to kick jazzer's ultimate knowledge to the curb, but every set of snow tires I have came across on cars feel to be super soft
same here, I think he's thinking about summer tread compounds or something and not thinking snow world.
Originally Posted by TRUEBLUE3934
Center tire wear is over inflation. The front end has more weight on the tires than the rear, so the rear pressures should be lower than the fronts. I have to agree that 30psi seems low enough, but it may be the pressure gauge you are using. Is it a high quality gauge or a fairly cheap one?
It's a good gauge, and actually the tire dealer inflated my snows. I checked them when I got home and they were spot on 30 lbs with my gauge so I know it's right.
I'll try lowering the air pressure, but 20 lbs seems low, I don't want to blow out a tire. I'll start with 27 or 28 and keep an eye on them.
Old Mar 29, 2011 | 01:51 PM
BraMas's Avatar
BraMas
So your running around on 225/50/17 all the time? I assume you have the white wall showing also? just bustin your *****. But really why?
Old Mar 29, 2011 | 02:02 PM
PoisonIvy's Avatar
PoisonIvy
Faulty tire pressure gauge? Sounds too much like over inflation.
Old Mar 29, 2011 | 02:49 PM
Those are my snow tires, I run 275/35/18 on all 4's for my summer tires. Skinnier tires do better in snow, that's why I went with that size, I need all the help I can get haha.
Used more than one gauge, and on top of that my front tires which are checked with the same gauges, are wearing perfect.
Old Mar 29, 2011 | 10:43 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
Try putting some white shoe polish from the shoulder of the tire around onto the tread and then roll the car several rotations to see how much of the edge of the tire tread is contacting the road surface. This may give you a visual on whether you are over inflated. If it is hard to see from just rolling it a few rotations, drive it down a straight road to wear the polish off the tire (avoid any hard turns which may alter the wear pattern).
Remember that the front tires should have a little more pressure in them due to the weight bias of the car. Same pressure front and rear will tend to wear either the center of the rears, or the edges of the fronts more.
Old Mar 30, 2011 | 11:36 AM
ok, I always just went based on the door tag, but I'll try running less in the rear since the front's seem to wear literally perfect.
Old Mar 30, 2011 | 11:44 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
The door plate recommendations are based on a fully loaded vehicle, if you routinely drive alone or with just on passenger, and/or with no cargo, tire inflation (in the rear especially) can be reduced...
