Treadwear problems
Ahh ok never knew that although now that I think about it that makes sense. I'm almost always alone, and I never really have anything in my car. Have a reccomendation as to what I should make my rear tire pressure to start out?
There's only one type of "soft" of which I am aware, and unless you are in a public place it is generally embarrassing...
Consider this also:
Micro = small
Soft = not hard
So, consider what sort of geek would name their company Microsoft?
Consider this also:
Micro = small
Soft = not hard
Cliffy, you're so smart its scary, I never looked at it that way.
Back on topic of "soft" snow tires here.... I think this may be an issue more of symantics than anything else. Snow tires tend to have LOTS of groves and wide openings between the tread blocks. This helps them to shed the snow that gets lodged between them so the tires are always looking for increased traction
This tread pattern would appear more likely to wear out faster on asphalt due to the lack of actual surface contact of the tire to road.
Jazzer supposin'
Jazzer supposin'
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
