squeak when turning left
Old Apr 10, 2011 | 05:44 PM
xterm11's Avatar
xterm11
Default squeak when turning left
Recently my car started to squeak when I was taking a mid to long left hand turn between 20-30 mph. I was doing the cobra brake swap this weekend and figured since it was on jackstands I would replace the spindle. Everything I read online pointed to this being the source of the issue. Well now it no longer squeaks on the mid to long left and turns but squeaks whenever I turn the steering wheel slightly to the left. I used plenty of grease on the spindle and torqued the nut to the correct specs.
I am completely out of ideas on what it could be and don't want to just keep throwing parts at it.
Old Apr 10, 2011 | 06:23 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
dry socket in the tie rod end / ball joint? does it do it at a stand still?
Old Apr 10, 2011 | 08:24 PM
xterm11's Avatar
xterm11
I've only noticed the noise when driving. Its a high pitched metal on metal sound. I will check out the tie rod end.
Old Apr 11, 2011 | 07:10 AM
AYEOH5.0's Avatar
AYEOH5.0
http://www.paladinmicro.com/PalMFrame00.htm?wks=rak
Old Apr 11, 2011 | 12:49 PM
Repzard's Avatar
Repzard
I had the same problem on my GT and it was what you stated.
(Tierods) dried out (Stock no zerks)
Old Apr 13, 2011 | 06:52 AM
xterm11's Avatar
xterm11
I replaced the tie rod and the squeak doesn't happen as often but will still happen she tiring the steering wheel 5-10°.
I took off the wheel and examined the rotor to finds light scoring around half the outer circumference (towards where the top of the pad sits) on the outside face of the rotor. I can't see any burrs or rub marks on the caliper.
I am at a loss for what could be causing this.
Old Apr 13, 2011 | 07:29 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
could be a loose wheel bearing, flexing under side load and causing the rotor to rub
guitarman376
Oct 11, 2015 01:47 AM
gagemcc
Sep 22, 2015 09:43 AM
degner122
Sep 16, 2015 07:09 AM
Sep 8, 2015 11:50 AM
Jose Corretjer
Sep 8, 2015 06:32 AM
