puttin in my sc!! need help...
ok so im ordering all my parts, but decided to inter cool, so from what i understand i can change a bit of what i order. like i dont need the vortec discharge pipe anymore correct? because i plan on just running aluminum pipe from inter cooler to intake.... i also cant get a lightning maf cuz its draw through and i need blow through correct? which means i need a pmas? the other thing is im not sure how to pipe the bov in? and which one do i buy and what pressure do i get it at? because it seems like thats adjustable? Im basically fabbing my own set up, buying a treadstone inter cooler, and their do it yourself aluminium pipe kit. Anyone heard anything bad about them? im sure ill have other questions, i just want to make sure i dont miss anything...id hate to go over budget and not be able to finish...
First thing, what is your budget? That would give us alittle more knowledge on which direction would be best for you. Second thing, you can still run a draw through setup intercooled but you will have better results going blow through. Third thing, the bov should be welded on the pipe that runs off the blower to the intercooler.
