swap
???? So you have a 98 v6 and want to throw in a 4.6 im guessing?
I don't think you can do it since you can't type a sentence.
You would need motor, wiring harness & computer for sure. Im not sure which tranny the v6's used in 98. If it is a different tranny add a Driveshaft to the list.
You can prob sell your car & find a 98 gt for cheaper.
I'm with Ryan... If you can't communicate correctly, there's no way you'll swap a motor. Also, it would be a grammer lesson, not literature.
That being said, it would be easier and cheaper to sell that and buy a V8. Those swaps will nickle and dime you to death unless you have a good donor car to pull parts from.
ok ryan so im not good with the grammar but here is the situation i have if you can help thats great, my 1998 mustang was given to me for a debt someone owed,now the car caught fire under the hood. the elect.wiring was distroyed and the motor was severly damaged. the wires were cut onthe pass. side before the firewall and unplugged on drivers side. next the motor and trans were removed and replaced with an 88 5.0 ho motor,with a c-4 3 speed. now the state of nj wont let the car back on the road without it being fuel injected to meet 1998 emmission standards. so I bought a painless closed loop fuel injection wiring hatness to be installed. b ut the problem is that the electrical wiring on the drivers side can be replaced cause it plugs in , but the pass. side the wires were cut now the qeustion still remains do i have to rewire the whole car or does the wiring coming throuth the firewall on the pass. side plug in somewhere inside the cab?
Matt's 95 Stang
Oct 5, 2015 07:16 AM
