Vortech V2 T-trim
The focus pump will handle your goals you have for now. I am running a focus pump with my kenne bell and it handles it fine. I also have a kb bap but it isn't wired in at the moment. I installed it in the car but disconnected it because I was going to rewire it to run it full time but I forgot to do it before my leave ended. I'm putting down 412/436 to the wheels and the pump wasn't even close to maxed out. Most people say the focus pump is good for up to 500ish give or take a little. I was tuned without my bap hooked in as well. And as they said the bap is a direct replacement in your stock fuel hat. You can pick up just the focus pump itself for between $70-95 normally, just check the parts for sale here or you could try over on svtperformance or corral they are normally abundant there. Baps can be found pretty easily as well.
Soldier GT
Aug 12, 2015 03:46 PM
0949er
May 23, 2010 10:46 PM
