Brake problems
Old Jul 18, 2011 | 08:05 AM
sdnrke1234's Avatar
sdnrke1234
Default Brake problems
My brakes are making a grinding noise, like metal on metal. It's not happening only when I brake, so I don't know that it's my brake pads or rotors. It happens when I am sitting still, too, and just pump the brakes. What could it be?
Old Jul 18, 2011 | 08:13 AM
dominant1's Avatar
dominant1
if they're grinding it means your down to the rivets that bond the pads. Go the safe route. get performance pads and rotors for about $500.00 and install them yourself...With brakes never settle for the cheap fix, your mustang deserves the best you can provide!
Old Jul 18, 2011 | 08:24 AM
Blk003GT's Avatar
Blk003GT
You dont need performance rotors. If u want to upgrade just get some nice pads.
But id change ur brakes and check the slide pins to make sure they arnt binding up and listen to the caliper when u compress the cylinder to see if thats making any noise
Old Jul 18, 2011 | 09:07 AM
sdnrke1234's Avatar
sdnrke1234
If it's the calipers making the noise, will it still need new pads?
Old Jul 18, 2011 | 09:33 AM
trailor's Avatar
trailor
take out the pads and see if they're the culprit. i've never heard of a grinding while sitting still, but since pads are the easiest place to start, do that first. if the pads don't have anything left on em, that could be your problem. either way, you're gonna hafta start by replacing the pads and rotor, and i would suggest replacing all your other pads too, and probably the other rotor across from the one you're replacing. and don't bother with "performance rotors" if you're not doing auto-x. just get OEM blanks, they're more than adequate for daily driving and your occasional drag racing.
Old Jul 18, 2011 | 06:31 PM
SyNdicateZ's Avatar
SyNdicateZ
wow...I am having the same noise when i apply brake whether rolling OR sitting still..Kinda sounds like a springy metal noice..
Old Jul 19, 2011 | 05:32 AM
uberstang1's Avatar
uberstang1
Chupacabra
Sounds like the clips on the pads, sometimes they rust and brake off the back pad. OP: Before getting all fired up and getting a thousand speculations simply check to make sure the pads have meet all you need to do is pop the wheel off.
Old Jul 19, 2011 | 05:33 AM
uberstang1's Avatar
uberstang1
Chupacabra
If the pads and rotors are fine and you don't replace either of the two items you can just replaced the caliper and be fine.
Old Jul 19, 2011 | 08:08 AM
astentine's Avatar
astentine
I had the same kind of noise, except t really only did it when I used the brakes and starting out from a stop. Turns out one of my calipers was stuck and all of pads needed replaced, and all four of my rotors had cracks in them. I would suggest either taking it a brake specialist with the expertise in brake problems (as the Ford dealership didn't notice my cracked rotors and Pep Boys saw them immediately) to get them checked for stuck calipers or cracked rotors, or of course if you know how to check, check it out yourself!
Old Jul 19, 2011 | 08:23 AM
turbo232's Avatar
turbo232
sounds like it's a good excuse for Cobra brakes.
Tivo304
Aug 28, 2023 12:19 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
