Change trans fluid
About 3,300. It's not terrible but it is definitely not smooth. I had the flywheel resurfaced when the clutch was replaced.
EDIT: I recall the stock clutch being a bit rough as well. I thought it was normal for it to have a bit of a rough engagement.
Our cars, the New-Edge Mustangs, are pretty much the last of the true muscle cars¹--basically the drivetrain from a 1/2 ton V8 pickup truck stuck on underneath a flashy body. As such they tend to have a number of quirky noises, rattles. etc. that more refined vehicles lack. I personally like it, just like the headlight switch on the dash. If the dimmer switch was on the floor it would feel just like home...
¹ - One of the specific design goals of the S-197 project was to move the Mustang further away from it's roots and make it more "civil". That was done so well that in 2010 they added a "sound pipe" to transmit intake noise into the cabin to make the driver think they are driving a real muscle car rather then a "luxury sports coupe"...
Like some luxury car companies that have an option to have a light flow of air coming through the vents to resemble the wind...just open the windows!
They want to appeal to more of the market, as opposed to a smaller section of real enthusiasts. And the sound pipe thing I actually read that awhile back in Car and Driver, I think? Regardless I have heard that as well.
Here's a sort of related bit of Mustang trivia that some "whippersnappa's" may not be aware of:
In the mid-80s Ford decided the Mustang needed a major redesign and in partnership with Mazda developed a front-wheel drive "more refined and sporty" coupe that would wear the Mustang nameplate. It almost made it to market as the "new, re-engineered" Mustang.
However "it" hit the fan when the Mustang community got wind of the project and because of public outcry the "new Mustang" became the Ford Probe...
Wouldn't that have been enough to gag a maggot?
Also, I have noticed that the **** gets hotter after the car sits not running, after a few hours its still warmer.
Am I right to assume this is still due to the shifter and **** conducting heat more, and from sitting still the heat from the tranny/motor/exhaust is just rising where it can?
LivingInThePast
Sep 16, 2015 12:20 PM
