tps sensor
Old Jul 28, 2011 | 11:05 PM
4v_mach1's Avatar
4v_mach1
Default tps sensor
Hey guys If I'm installing a new tps sensor, whats the voltage supposed to be set at during idle/wot?
Old Jul 29, 2011 | 05:32 AM
uberstang1's Avatar
uberstang1
Chupacabra
The TPS sensors dont have adjustability on these cars, you simply install it and the computer will re-learn its setting. You can shim them or anything like you could of the old 5.0s cause the computers is still gonna adapt to it.
Old Jul 29, 2011 | 01:12 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1...
The PCM continuously monitors the TPS output and considers the lowest steady state observation to represent "closed throttle", technically it's a ratch (reverse latch) value.
Higher values can be learned, however the time at which higher voltages must remain steady to be learned is quite a bit longer than for lower-than-learned values.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
