PLEASE HELP WITH HEATING PROBLEM!!!!
Old Aug 6, 2011 | 08:11 PM
mustanglover3's Avatar
mustanglover3
Exclamation PLEASE HELP WITH HEATING PROBLEM!!!!
Not too long ago, I bought a 1996 Mustang GT V8. Everything is perfect despite this annoying heating problem that I can't seem to figure out what the problem is. It only overheats during very hot weather and turning the AC makes it overheat even worse. Whenever it got really bad, the antifreeze would POUR out of the bottom, but we have inspected everything and can't seem to find where it's coming out of. So, I have put in a new thermostat because the older one wasn't working as well anymore. That didn't fix the problem. Then, we put in a new 16" radiator fan, because the previous owner put in two 10" fans that didn't seem to be cooling the engine down enough. Unfortunately, the new fan hasn't completely fixed the problem. Can anyone PLEASE give me an idea as to what it could be?
Also, it idles kind of rough at times, and sometimes it feels like the car is going to shut off when the RPMs get too low. Any ideas as to what that could be?
Thanks!
Old Aug 7, 2011 | 12:33 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
It sounds as though the radiator is clogged--get it flow tested at a radiator shop--or just buy a new one as they do not cost that much, $90 to $130 at RockAuto.
Idle problems are generally caused by a bad IAC...
Old Aug 8, 2011 | 03:33 AM
mustanglover3
Alright thanks for your help! I'll try that
Old Aug 8, 2011 | 08:03 AM
KillJoy's Avatar
KillJoy
With the engine cold, remove the overflow cap, and run the engine. When at full operating temperature look for water flow inside the coolant bottle. You should see a good amount of water flow in the bottle. If not, id suggest removing the water pump, and checking the impeller.
Old May 18, 2013 | 05:56 PM
mloyd's Avatar
mloyd
Thanks for the ideas I will try it tomorrow. Thanks, Mick
jma2
Jul 10, 2023 01:00 AM
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
