Replacing Clutch-Opinions Welcome
It's come time to replace my clutch and throwout bearing and I just wanted to make sure I've got everything i need. This is what I had in mind...
http://www.lethalperformance.com/tra...0-spline-p-555
http://www.americanmuscle.com/ford-t...ring-7904.html
I want to replace the cable as well but don't know where to get one(dealer?)
Are there any other parts I should be looking for?
I've stalled long enough with this issue(no pun intended) and want to get it done properly and as soon as possible. Thanks guys, appreciate any feed back
Definatly use a factory cable along with a triple hood quadrant, aftermarket cables are junk and snap. Also check out the fingers on the clutch for and also the ball pivot for the fork, if they look crappy you can get a new ball pivot and clutch fork for around 40$. Do you plan on using a stock flywheel resurfaced?
Looks good! And if you look up Tousley Ford Parts in google, they have awesome prices on OE ford parts. You can probably get a stock cable from them. They sell parts at 10% over cost. Good luck!
