Purge Flow Sensor & Solenoid
Guys,
I recently had a 1443 error code. I bought a new purge flow sensor and solenoid. I got to looking at the rubber lines that the sensor and solenoid is connect to and they are not in great shape. These bad lines are also probably contributing to my problem. I have been trying to search the web and can't seem to find a place to buy new hoses/lines. Any guidance would be appreciated. Thanks!
You need to measure them, to find out what the inside diameter and length are. Then go to a FLAPS and tell them you wish to buy bulk vacuum hose having the needed ID and length.
If the original hoses were moulded with tight bends you may have to get longer lengths to allow looping or alternative routing, and/or purchase some plastic elbow fittings to make it all fit up.
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
