Vortech S/C
Old Sep 15, 2011 | 11:10 AM
Harryman2002's Avatar
Harryman2002
Yeah, they're all pretty much the exact same other than the oil thing. Just get whichever you can find the best deal on.
Old Sep 15, 2011 | 01:15 PM
Rockwell28's Avatar
Rockwell28
Originally Posted by Repzard
V3 are the best IMO.
No hacking your oil pan for oil feed line.
Best is debatable on the self contained vs the oil line units. the self contained v3 has that small amount of oil in it that it continuosly uses until you changes it. the oil fed ones are sucking from a 6qt supply of oil that is also cycled through the oil filter and gets changed out with the oil changes.
Old Sep 15, 2011 | 05:57 PM
97stanger's Avatar
97stanger
id rather change my oil once
Old Sep 15, 2011 | 07:21 PM
supermario's Avatar
supermario
Is it easy to change the oil on the V3?
Old Sep 16, 2011 | 07:27 AM
gears94gt's Avatar
gears94gt
the v3 comes with a 6inch attached stainless steel hose to drain the oil, and if you get it new they supply you with the first oil change .
Old Sep 16, 2011 | 08:37 AM
Rockwell28's Avatar
Rockwell28
a few ounces of continuoulsy used oil vs 6qts of filtered oil supply to suck from. pro's and cons to any and eveything. if self contained was the end all be all then all of their head units would be self contained. all turbos would be self contained too.
Old Sep 17, 2011 | 04:56 AM
04orngegt's Avatar
04orngegt
been running v1 for two years. no complaints loud and everyone can hear it.
Old Sep 18, 2011 | 05:29 PM
MustangMan00's Avatar
MustangMan00
v1 if you want to attract attention sounds like a jet plane pulling up anywhere. as far as tapping the oil pan, it seriously isn't that bad at ALL, despite the way it sounds
Granatelli Sales
Mar 21, 2016 06:16 PM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 16, 2015 07:53 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
Soldier GT
Aug 12, 2015 03:46 PM
