Air / Fuel problem
Hey everyone,
I got all the pipes connected, hoses attached, BOV, MAf, etc. Oh and then added new gas. Went to start it, it fires up but then stalls. The longest it stays on is a couple of seconds. Is this because the air fuel is so far off from a 3.6 non intercooled to a 3.12 intercooled set up? I'm hoping that's the issue and that I didn't do something else in the process...
Thanks for the opinions.
To answer your question no. You're A/F is controlled by the MAF and the onboard computer while in open loop. Did you convert to a blow through setup? If so, did you get a new tune for it? Also, if you can post a picture of your engine bay. I may be able to just look at it and see what is setup wrong about it.
^ like kerns said, if you switch from draw through to blow through (which im almost positive u did?) Then that is why its not running long, mine did the same thing until my tuner put a base tune on it. The base tune was enough to get a short little first pull on the Dyno done which was enough to start tuning
ShaneB26154
35
Mar 4, 2021 04:05 AM
