Most horsepower from a 96GT W/O PI swap or F/I?
Old 03-23-2012, 06:12 PM
Dpizzle
Dpizzle's Avatar
Default Most horsepower from a 96GT W/O PI swap or F/I?
Whats the most someone can or has attained without the PI swap or F/I on a 96-98GT? I'm just curious because I don't have the mechanical know how to do the PI swap for one, and this car has high enough miles I'm not going to bother with F/I plus its just a daily driver, but I am wondering how much the common bolt ons will net this car if its worth it.
MAC CAI
Steeda UDP's
Stack 70MM TB
Stack Upper Intake Plenum
Stock headers to off road h pipe no cats to flowmaster 40's
SCT SF3/X3 Power Flash
thats what i have and i was told MAYBE 200hp? Seems slow lol
Dpizzle is offline
Old 03-23-2012, 06:36 PM
03greyGT
03greyGT's Avatar
Without tearing into the engine, youre really not gonna get a good amount of power out of a NPI car. You can do the usual bolt ons, but its not gonna be much of a difference. I dont see if youre auto or 5 speed, but an auto is obviously gonna feel even slower. I just did some work on my buddies 96 GT auto. I did PI cams, PI intake, throttle body and plenum, timing adjuster, off road H pipe, and Magnaflow catback. You can tell adifference, but even with all that it wont spin the tires from a stop. This is also with the stock 3.27s as well. You could look into gears to make it better off the line...Id go with atleast a 3.73 gear, but if it were my car Id go 4.10s.
03greyGT is offline
Old 03-23-2012, 08:26 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
As mentioned above, not a lot of power to be gained with bolt-ons to a non-PI motor.
Nitrous is the only way to get good power without the H/C/I swap or FI.
TRUEBLUE3934 is offline
Old 03-23-2012, 10:18 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
look into cams, you can actually run a VERY aggressive cam on an NPI motor due to the intake valve design, talk to Nick @ MHS he'll hook you up
with good cams, a PI intake and all the other supporting mods i see no reason you cant make 240-250rwhp...
4.10's in that car will actually be VERY fun
* FWIW, Nick can degree the cams for you, so you literally take them out of the box and install them per his directions and thats it; no degreeing the motor or cams, just a direct swap from the stock parts. Cam swaps are actually pretty easy on these cars and NPI springs are safe to over 7000 rpms so no need to swap them out either*
sn95_331_GT_ yellow is offline
Old 03-24-2012, 04:58 PM
TRUEBLUE3934
I agree that cams can make a difference, but he indicated that he has little mechanical know how. I think he is looking for fairly simple bolt-ons and their benefit.
The non-PI configuration will really hold him back from "good" performance.
As usual, my first suggestion is for him to save and install gears.
Old 03-25-2012, 09:03 AM
Justfloatn
Justfloatn's Avatar
Hi new here.
I would change the gears first. Nothing you do to the motor with those heads will add that much seat of the pants feel. Gears will make it quicker out of the hole and more fun to drive.
Justfloatn is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Most horsepower from a 96GT W/O PI swap or F/I?
