Suspension mods...where to start?
Hey guys,
I am currently pondering what mods I want to get next for my 1998 GT Vert with a 5-speed.
I was going to go ahead and get a plenum+throttle body, but then I realized it might be a better idea to do some suspension work, especially because it is a convertible.
So I am wondering what I should do to the suspension to make it handle bumps better, put the power down better, take turns better, etc.
I was thinking of starting off with Maximum Motorsports full-length subframe connectors. I am not sure where to go after that, however. What are the most cost effective suspension mods?
Thanks,
DutchManDann
Thanks,
DutchManDann
Dutch.... are your ULTIMATE goals, improved cornering or off-the-line?
Some suspension mods will help with both, but a decision must be made on direction, if you want to really accel at one or the other. In order of what I see as the best starting point:
1. Tires ~ #1 item on your car to help maintain grip of the road. The type of driving will dictate the make/model/size of tire
2. FLSFC's ~ Lots to choose from, must get them welded in place
3. LCA's ~ At least one spherical end and make/model depend on 1/4 mile use and tires you would run there.
4. Decision time...
Jazzer
4. Decision time...
Jazzer
4. Decision time...
Jazzer
4. Decision time...
Jazzer
It seems Subframe connectors are a good investment from what you guys are saying, so those will probably be my next mod. I already have a strut-tower brace that I am going to install as well so between that and the subframe connectors, I am hoping to reduce the body flex significantly
I think my ultimate goal is off-the-line. I don't really like cornering quickly anyways i don't know why. I want the power to be put to the ground better.
Oh and my car was already lowered slightly...I think like 1/2 inch or so. No CC plates or anything. It's something that I will have to re-do myself at some point down the road because I don't really trust that the previous owner did a good job
How are these: http://www.americanmuscle.com/maximu...onnectors.html ? They are the unpainted Maximum Motorsports full length. I would sand them down and paint them before the install so as to prevent any further rust under the car.
