Moonshine's Cobra build!
Old Nov 30, 2012 | 05:19 AM
  #21
99 GT vert's Avatar
99 GT vert
when i put my turbo kit on i just pulled my oil pan off and welded a an fitting on to it made it alot easier not having to worry about stripping out the threads
Old Nov 30, 2012 | 07:37 AM
  #22
flyboy1294's Avatar
flyboy1294
That definitely seems like an easier route in the long run. If you tapped the pan while it was still on, wouldn't it risk getting shavings in the engine?
Old Nov 30, 2012 | 07:56 AM
  #23
uberstang1's Avatar
uberstang1
Chupacabra
U just run oil to drain them out, that plus the oil filter and pickip screen will do the rest of the job.
Old Nov 30, 2012 | 08:31 AM
  #24
Moonshine's Avatar
Moonshine
I'm definitely not pulling my K member just to weld a bung on my oil pan...lol
Drill, tap, and seal baby!
Old Nov 30, 2012 | 10:55 AM
  #25
flyboy1294's Avatar
flyboy1294
Ah I see. I didn't think about pulling the Kmember either. I'm really just going to shop hard for a V3 I think.
Old Nov 30, 2012 | 11:00 AM
  #26
dwtjr3's Avatar
dwtjr3
This^, and when I put the new oil in I only ran it about 200 miles and changed it to confirm that there wasnt much of any metal shavings in there.
And if you grease the tools when you are tapping the pan the grease catches the majority of the shavings.
Old Nov 30, 2012 | 11:01 AM
  #27
dwtjr3's Avatar
dwtjr3
This is the way I felt haha
Old Nov 30, 2012 | 11:22 AM
  #28
chillindamost's Avatar
chillindamost
One good trick I learned is to put grease on the tap and it collects most of the shavings.
Old Nov 30, 2012 | 04:03 PM
  #29
Moonshine's Avatar
Moonshine
Is there any way to get my car to run...even just a little before I take it to the tuner so that I can work out any potential bugs? fuel leaks, oil leaks, vacuum leaks etc.
Old Nov 30, 2012 | 04:33 PM
  #30
99 GT vert's Avatar
99 GT vert
i put a tubular k member in mine so it was already out.
and on the starting the car before the tune just call the tuner and have him send you a can tune just to get an idea if you are having issues
