Stupid question of the day?
It keeps leaves and crap like that from getting around your filter
Thanks, I haven't pulled the cover off yet, does the vortech s trim use the stock mass air?
Would the C&L meter work better? He said he was going to use the C&L and k&n filter with a power pipe, but can I use this with the factory vortech piping? Would love a power pipe, but not in budget right now
Is your setup a blow through or a draw through? This changes the location of the MAF. Either way though, your MAF will be on your intake tube. Look for wires and a plug going into the tube. As some have said before me, post a picture and we will be glad to point out of the sensor for you.
As long as your current MAF sensor is giving correct readings you will not see an improvement with the C&L mass airflow sensor. All either one does is send data to your PCM. In short, if it is working right, leave it alone.
If a power pipe will work with your setup, many members on the forums have had a lot of luck building their own for just a few bucks. Here is a link for some information about it!
http://www.moddedmustangs.com/forums...ower-pipe.html
Thanks for the article on the HO made power pipe, total shipped, $97.00 .
Sorry but my car is in storage for winter, so I haven't checked anything. But i did google vortech 2000 mustang, and the images are the same as mine..
I have a pipe going from T.B. to 3" pipe into supercharger, no mass air?. Now what's on the other side of the fender I have no clue, I guess I'll find out when my HO made power pipe stuff gets herr.
? How do I make my car have that blow off noise? Do I have a blow off valve? My super charger is super quite, I was expecting 03 cobra noise, it ain't no whipple.
