Bad news about oil leak, what should I do? (They drilled into my engine???)
Old Mar 14, 2013 | 04:03 AM
Cali_Swag's Avatar
Cali_Swag
The mechanic I talked to made it seem worse than I think it is. I was doing a little research on stripped valve cover bolts and it seems you have to re thread it. I guess they didn't do it right though. Hopefully I can get this fixed and have it not cost an arm and a leg.
Old Mar 14, 2013 | 07:46 AM
dwtjr3's Avatar
dwtjr3
If you pull the cover off without stretching the gasket you can reuse the gasket but still use some rtv as well.
Just have to take the bolts out the try and wiggle the cover out
Old Mar 14, 2013 | 09:14 AM
uberstang1's Avatar
uberstang1
Chupacabra
Is that new bolt tight? u may just need to seal the vale cover, wont know untill u remove it
Old Mar 14, 2013 | 01:09 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
I'm by no means a professional mechanic, so when I was replacing my cylinder head and it came time to put the valve covers back on I spent an abnormal amour of time swearing at the garbage aftermarket gaskets.
Sounds like worst case scenario they can just fill and rethread the head.
Good luck.
Old Mar 14, 2013 | 01:44 PM
Cali_Swag's Avatar
Cali_Swag
Ok so I just went in and tried to figure this out. I tried to tighten that screw but it just kept spinning, that means its stripped right? I could not tighten it down all the way. I took it out and changed it with another screw on the same valve cover, still no luck getting it to fasten. Turns out the bigger bolt just had a bigger head but the screw itself was the same size. That mechanic is an idiot and didn't even unscrew it before making such claims and he did to me scaring the heck out of me.
So now that I know for sure that it is stripped I can go ahead and get it re threaded.
Old Mar 14, 2013 | 08:55 PM
uberstang1's Avatar
uberstang1
Chupacabra
Yep just needs a helicoil
Old Mar 15, 2013 | 12:11 PM
Forced Air's Avatar
Forced Air
Exactly what I was going to say. Helicoil and be done with it.
Old Mar 21, 2013 | 09:53 PM
69MustangCoupe393cid's Avatar
Good luck.
^This. I'll bet you have aftermarket gaskets like felpros. Take them off and throw them out. Mine were leaking within 3k miles. I took my old ORIGINAL FACTORY FORD (with 87k miles on them mind you) gaskets, wiped them off and tossed them on. Bam leak gone. Point here is go to FORD and buy FORD gaskets.
^This.
If there is not enough material to helicoil, try a bigger bolt and tapping new threads in the hole. Far as RTV you don't need any on the gaskets, just on the 2 (or is it 4?) points where Ford specs it. And just a dumb tip, check all the other bolts and make sure they are torqued to spec.
djbigskrilla
Sep 20, 2022 01:04 AM
soulcaliber39
Dec 28, 2016 04:57 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
eastexsteve
3.7L V6 Technical Discussions
Dec 4, 2015 05:41 AM
yurizx6r
Aug 11, 2015 07:50 AM
