tune time for the cobra
Well i figure i will see what all you think the cobra will make when it gets tuned here in the next week or so. it will be tuned on 93 for now and hoping to be around 19 psi
here is a mod list i may have forgot some but let me know what you guys think and if you get close to the hp numbers i will give you a cookie
Motor
Mod Max/ CP .020 over piston
Factory Rods
Factory Crank
ARP Head studs
Heads gone through with valve job and guides replaced
Nazman Ported 03 Mach 1 Lower Intake
Stock 01 Cobra upper made to fit SBTB
03 Mach 1 Timing chain cover
03 Mach 1 Crank pulley
ARP main studs
Accufab single blade throttle body
Stage 8 Locking header bolts
Evenflow head cooling mod
03 Mach 1 upper and lower radiator hoses
Power adder
Hp Performance Twin 60mm Turbo kit
2- Garrett Journal bearing turbos (rebuilt winter of 11-12)
2- 38mm Tial wastegates
Custom Made 2 ½ O/R H
2 ½ Bassani Stainless Steel Catback
Fuel System
Glenn’s Performance 1300 HP sleeper triple pump fuel system
Fore Black Fuel rails
Acceleronics/Delphi 95 lbs/hr injectors
Accerleronics Versafueler injector driver
Motor
Factory Rods
Factory Crank
ARP Head studs
ARP main studs
Power adder
Fuel System
