2000 GT Steering U-Joint
I recently got a 2000 Mustang GT, and my steering is a bit sloppy. I know it's my U-Joint, you can hold the lower half of the column, and move the wheel about an inch either way and see the play in the u-joint. I'm looking to get it fixed, just can't figure out the part # for the factory replacement. Anybody happen to know the part number, or a good replacement part?
I've also got a pop in the front end on the drivers side, I'm guessing is from a tie-rod end. I'll hopefully have it up on the lift sometime this week and check it out.
I lifted this image from another thread here, but it's the u-joint pictured that's bad on my 2000... I've checked the alldata info, and the ford service manual, but haven't seen a part #, or instructions as to how to replace it (or if you just have to replace the entire shaft).
trashxtrash
09-20-2015 10:49 PM
