New NITTO Extreme Performance NT555 Tire - 315/35-17
Are u making that number up? With an s trim on a 2v u would need a ton of boost to make tht power and considering your car isnt intercooled or aftercooled well.... Its basically impossible. You pretty much couldnt run nitrous on top of that on pumpgas, and your fuel sysyem cant support it
Something just seems way off here. What size pulley is on that s trim, u would pretty much need to max that blower out to hit 526 on a 2v which would be 17-18psi on ur setup, those pistons and the svo heads( which flow about the same as pi heads) would put u in the ballpark of 10:5:1 compressions, and ur claiming your doing this all with a non cooled supercharger and pump gas? I highley doubt it this car sounds like a 390-410rwhp car, putting nitrous on that car is totally outnof question on its curret setup.
Agree with kieth. I have done just about every mod on these 2vs with an S, Si, and now a V7 JT. No way 526rwhp is happening through a 2v, no cooler, no meth. Hell my Si was maxed out around 15 psi and that thing ran circles around my S trim
Ya theres no way he can get the boost he needs for those power levels, in a previous post in his history he claimed 455 with 12psi which even souds bs for the car
What Nitto Tires Are The Best All Around Tire ? The 555 Drag radial or the NT05 Drag Radial? I have ran the 555 the last 2 sets and had good response ,1.87 60ft @ the track and good hook on the street . I have put the NT05 in the front to do some road course time and sorta wanted to match the NT05 for the back but do more drag than road course. Also Going to replace the stock clutch this spring and looking for a good streetable clutch that will take the track , any suggestions will be taking , Thanks
Here is where he said this,
Once I saw the first picture I remembered his previous post then I saw the increased HP number haha
https://mustangforums.com/forum/4-6l...er-40-a-2.html
