Cam position sensor....
Old Jun 27, 2013 | 01:13 PM
Saabonthis's Avatar
Saabonthis
Default Cam position sensor....
So I replaced my cam sensor because my engine light kept coming on with the same code for the cam sensor. Light keeps coming out even after new sensor. I've read that it is highly likely that the alternator is the culprit. A diode or something goes bad and causes interference with the sensor? Anyways I was mainly wondering what voltaoshould I typically see from the alternator when the car is idling and driving? And should the volts fluctuate much? On idle my car reads from 11.5 - 12.3. Higher rpms bring 13-13.9
Old Jun 27, 2013 | 01:36 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
at idle it should be in the 13s and higher...if its not charging at idle, replace it... I believe you answered your own question there bud
Old Jun 28, 2013 | 11:51 AM
Saabonthis's Avatar
Saabonthis
New alternator fixed it. Running better now.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
