started build.
Old Oct 31, 2013 | 07:28 AM
uberstang1's Avatar
uberstang1
Chupacabra
If you do the 8 rib swap yourself its not that expensive, I found a used 10% OD crank pulley from ATI for $175, $80 for my procharger pulley direct from procharger, then I just went tot he junkyard for a f150 alternator/powersteering/and f150 ac delete pulley. Threw them in my blasting cabinet then had them powdercoated. You can leave the water pump idler and tensioner pulley as is.
Old Oct 31, 2013 | 08:27 AM
Bman2000's Avatar
Bman2000
i thought the new ones might be built better, guess not. I was planning on doing a teksid swap, since i have a windsor motor now, it means i need the timing cover off a i think 94-95 thunderbird? anyway once i get that, im not sure my tensioner will be the same will it? for that matter i didnt even think about the supercharger bracket? also im keeping my ac not giving that up in the name of speed....
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
5.0 kevo
Sep 3, 2015 06:24 PM
