97 mustang no power to 1 brake light
so basically I built a complete 97 gt. im just about finished with it. this is the last problem I have . my driver side brake light isn't working or the turn signal on the back driver side . there is a green/pink wire that is supposed to have power for the brake light and turn signal and it dosent .but the front turn signal works . does ne one have ne idea if its just a short in the wire or what. thanks for your help.
It sounds like you have an open condition in the wire. A short condition would be if the postive (12 volts) was shorted to ground thus blowing fuses. I would recommend checking if there is 12 volts at the origin of the wire and then woking my way down the circuit checking at the vaious connection points.
Diode Dynamics
28
05-26-2022 12:02 PM
