SOLVED 2 minor problems !!!!
My '98 GT was having 2 issues recently -
1. loud "squeel" at start-up &/or when the A/C comp. came on : after reading about similar sound on this forum, replaced the harmonic balancer, which was coming apart at the internal rubber ring : FIXED !!
2. she was cutting out sporadically at cruising speed; after spending big bucks on coil packs, wires, plugs, filters (no codes) I found the main battery ground cable to be loose and corroded on the block. Also removed the cheap bolt on terminal & replaced with new cable assy : FIXED !!
*Now I got a dependable daily driver ! thanks forum
Golfsito
Oct 6, 2015 11:02 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
trashxtrash
Sep 20, 2015 10:49 PM
LivingInThePast
Sep 16, 2015 12:20 PM
