Longtube Install by me
Old Nov 1, 2006 | 06:31 PM
  #21
scramblr's Avatar
scramblr
Default RE: Longtube Install by me
ORIGINAL: Haulupki
The anti seize is nice but not critical. The stock studs came out easily and they did not have any lube on them. As long as you start all of the bolts by hand you'll be fine. The biggest problem with aluminum threads is the first thread can get damaged easily by the bolt if your sloppy with it.
Then I guess I better be careful, huh? Thanks for the input...
Old Nov 1, 2006 | 08:37 PM
  #22
spdbrake's Avatar
spdbrake
ORIGINAL: scramblr
ORIGINAL: Haulupki
Scramblr,
I see you are on an AFB.
The Techs in the Turbine Engine shop will have some. Stick with Copper if possible, if Nickel (exterme hi-temp) is all they give you, wear latex gloves and wash up when done (poisonous).
Its not for the assy of parts but for dissassembly later.
Stainless and Alum gall particularly where heat is addded. Typically the threads weld themselve together and your left with a bolt covered in aluminum threads. (Thats why they make Heli-coil kits).
In aviation it is considered "asking for it" to not use it on certain landing gear and engine parts.
Old Nov 1, 2006 | 10:09 PM
  #23
CrazyAl's Avatar
CrazyAl
I've never worked on an airplane. However, I've done enough wrenching on cars, boats, motorcycles, and industrial equipment to consider anti-seize mandatory on just about every fastener you come across.
It is so much nicer to work on anti-seized parts--even if the parts aren't in a corrosive enviornment, things just go together and come apart so much easier.
IMHO, skipping anti seize on exhaust parts and spark plugs is also "asking for trouble".
Old Nov 2, 2006 | 01:23 AM
  #24
scramblr's Avatar
scramblr
Okey Dokey, Guess what I'll in the hunt for today? Thanks much for the inputs!!!!
Old Nov 2, 2006 | 03:00 PM
  #25
scramblr's Avatar
scramblr
Woohoo, got some at the Auto Hobby shop on base. They have a can of it they use locally. He gave it to me and asked me to bring it back when I'm done...pretty cool.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
