GEARS
Old Nov 22, 2006 | 12:22 PM
shiffty's Avatar
shiffty
Default GEARS
I WANTED TO KNOW IF THE GEARS IN MY 06 GT WOULD BE THE SAME THAT ARE IN A 02. I HAVE BUDDY THAT HAS A BRAND NEW SET OF GEARS FROM HIS 02 AND IF THEY WILL WORK IN MY CAR THERE MINE. COULD SOME ONE HELP ME OUT!!!!!!
Old Nov 22, 2006 | 12:55 PM
shiffty's Avatar
shiffty
Default RE: GEARS
OK I HAVE HAD ABOUT 11 HITS NOW AND NO ONE CAN ANSWER THIS QUESTION....
Old Nov 22, 2006 | 01:01 PM
CrazyAl's Avatar
CrazyAl
Default RE: GEARS
If your buddy has a GT and you have a GT, then they will fit. Both have the 8.8 ford axle.
However, if your buddys gears are used, then I wouldn't buy them. It is impossible to get them set up to the exact same pattern. Since they would be already worn in on a different axle, they will whine in your car. Only get them if they are BRAND NEW.
Old Nov 22, 2006 | 01:04 PM
shiffty's Avatar
shiffty
Default RE: GEARS
NOPE THERE BRAND NEW AND I DONT EVEN HAVE TO PAY FOR THEM....... THANK YOU FOR YOUR HELP
Old Nov 22, 2006 | 10:59 PM
mustangman02232's Avatar
mustangman02232
Default RE: GEARS
used gears are fine, my buddys V-6 has 3.73s out of a ranger with 145k on em and they are fine just check the teeth on them
only buy them if they are 4.10s/4.30s
Old Nov 27, 2006 | 10:38 AM
MBDiagMan's Avatar
MBDiagMan
Default RE: GEARS
It is NOT impossible to set up used gears properly if they are in good condition. It will likely take more work than simply installing a set of new FRPP gears using the same shims, but it is NOT impossible.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
