UDP ???
If you add a S/C, take the UDPs off and put the stock pullies back on.
The idea of the UDP is to slow down your accessories which in turn will free up HP to the rear tires. When a blower is added, the faster it turns the more boost you get and the more HP is made. If you had a UDP system on, that would slow down the blower and not make as much HP. With most blowers you can change the blower pullies to make it turn faster and make more HP.
ORIGINAL: nhvickery
r UDP's worthless if im goin to get a s/c?
