4.10's are in!!! but....
So, I got the 4.10's in on wednesday... wow! I like the difference.... they dont really effect the everyday drivability of the car... I deffinitly recomend them.
However I am getting a whistling sound when I am deccelerating.... it starts at about 40mph and just gets more high pitched if im faster.... dont know if its the gears, if its because of the break in period, or if they are bad.... the mechanic said that everything lined up perfectly but I would like some feedback from some of you experts.... They make no noise when my foot is on the gas.... only on the backlash of me with my foot off the gas or in nuetral.....
Thanks
Thanks
RE: 4.10's are in!!! but....
I'm no expert, but i'm not getting any whistle sound when decelerating. I actually had more of a whistle with the stock gears, but only when decelerating in a low gear like 1st or 2nd.
What gears did you buy?
No whistling with mine either. I can hear the gear when I first accelerate to about 10 mph's. But its not a whistle. Almost sounds like a watch ticking. You really have to listen for it though, it's that minute of a sound.
I went with motive gears. kinda got suckered into buying them,.. then got stuck with them.... rpm outlet doesnt have the best customer service...
I dont hear anything while accelerating... the whistling sound is basically hearing the gears spinning at a high speed i guess... its not so much a grinding though... didnt know if it was normal.
This is more of the reply i was looking for.... im hoping its just for the break in period.... its not that annoying or anything im just worried about it.... Im one of those guys that hears everything.... its only loud enough that if i put the radio onIcant hear it....
ORIGINAL: zkiller
whining on deceleration is a sign of incorrect installation.
Is it gonna get worse...? the mechanic is well known for building rear ends... he said that the pinion lined up perfectly and everything.... andthat the noise was probably because of the fact that that gear is so tight......
ORIGINAL: howarmat
motive gears have been known to have problems....rpm outlet has been documented tons on this forum as well as others.
